I wish to purchase a Router. Max I can spend is £120.
Whihc router is best to use and is compatible without to much configuration for IRC, DC++ and Bittorrent.
Thank YOU
The Linksys routers have always performed well for me... plus, they're feature-packed.
Some Linksys routers also allow other firmwares to be used.
Nothing can stop me now, 'cause I don't care anymore. -
It is really your personal preference.
I use a airlink nat router that has a full featured hardware firewall.
I paid 40 bucks. It works very well. -
Cicso 2600 with PIX....Oops you said under £120
Cisco also own Linksys, so I would go with a linksys -
Originally Posted by stiltman
Go to:
http://www.ebuyer.com/customer/home/
look in the Networking tab/select Wired or Wireless and from their your type of Router....you should find plenty well within you budget (read the comments)...I'm using a 'cheapo' ORIGO and its pretty faultless..it cost about £30 with del.
Which Firewall To Use In Windows 7?
By V Bot in forum ComputerReplies: 23Last Post: 30th May 2011, 22:34 -
Is built in Vista firewall any good if not what recomended + parrallel port
By Rudyard in forum ComputerReplies: 20Last Post: 28th Jul 2008, 02:58 -
PC Tools Firewall Plus ??
By ofield1 in forum ComputerReplies: 8Last Post: 18th Mar 2008, 14:08 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34 -
Comodo Firewall Pro - Free firewall
By bluemoss in forum ComputerReplies: 7Last Post: 10th Nov 2007, 09:44
