I recently purchased a DVD recorder (+R) and want to tidy up the captured files. I downloaded the latest version of DVDlab Pro and all went well importing the first 3 VOB files. When I import the 4th one, the timecode is screwed up, and when I try to import the 5th one, it hangs my PC. I decided to install DVDlab Pro on my work PC and tried importing the same files, and all five import without a hitch. The timecode on the 4th & 5th files are messed up but I have sorted them. Both PCs are running XP Pro. Home PC is SP1, work PC SP2. Home PC is AMD2500+ with 2GB RAM, work PC Pentium IV 1.7GHz with 256MB RAM. Home PC reads from a DVD writer and the work PC is just a DVD drive. I even tried installing it on a clean windows install and still get the same problem. Any suggestions as to why the home PC hangs?
AutoGK hangs when importing an AC-3...
By takearushfan in forum EditingReplies: 6Last Post: 28th Jun 2010, 06:58 -
Weird problem importing son format subtitles from TS in DVDLab Pro
By Talayero in forum SubtitleReplies: 1Last Post: 15th Apr 2009, 04:47 -
Importing VOB files--iMovie, Final Cut Express? New to Mac
By Theresa in forum MacReplies: 14Last Post: 7th Apr 2009, 08:54 -
Importing menu transitions from a DVD to another with DVDLab Pro
By lorix in forum Authoring (DVD)Replies: 7Last Post: 6th Nov 2008, 12:52 -
Problems with importing converted vob into Premiere Pro
By fishytastic in forum EditingReplies: 6Last Post: 16th Oct 2008, 14:18
