Hi everybody...
Is there a method to remove the language selection menu
wich starts at the beginning of some DVDs...?
e.g. Chronicles of Riddick RC2 (English / German)
(I want the german menu)
I tried it before using DVD Stripper,
but the problem is that the "DVD start point" is set to the EnglishMenu
which is already removed....So the DVD won't start![]()
Tnx in advance... AcmE85
DVD Remake Pro, PGCEdit, IFOEdit can probably all do it. You will have to look at them further to work out how.
Read my blog here.
I don't think DVDStripper could do what you want but there's a DVDRemake guide HERE
that might not be the guide you want as you could also delete the English menu with a click or two but it depends on the DVD Structure -
There's two ways you can do it with PgcEdit (free prog, really cool):
- You can make the DVD jump to the main menu upon insert (see my guide in my signature) thereby bypassing the language menu, and everything that comes after until you get to the main menu.
- You can bypass the language menu only only and keep all the rest. 2COOL has a guide for that, which you'll find a pointer to from my guide page.
It's an easy job, really.
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
How to remove the language selection menu from BR Disc
By The-One in forum Authoring (Blu-ray)Replies: 21Last Post: 27th Apr 2014, 16:00 -
Removing bad language from DVD for my kids
By adaboy in forum EditingReplies: 36Last Post: 4th Sep 2010, 21:57 -
removing subtitles (foreign language) from a downloaded movie
By gizmobently in forum Newbie / General discussionsReplies: 3Last Post: 26th May 2010, 22:40 -
How to create the languege selection menu?
By ss213 in forum Authoring (DVD)Replies: 4Last Post: 5th May 2010, 02:59 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29
