Hi, I've recorded several very good quality mpg files (last weekend's NFL games) using a Hauppauge WinTV-PVR-USB2 card. The video is outstanding, since I fed the Hauppauge card via an S-Video cable coming out of an over-the-air HDTV receiver. My problem is the audio, which sounds like crap despite my having used the default settings for the card (MPEG-2, 384kbps). Everything sounds either slightly distorted/raspy or as if it had been recorded at too high a level. Sort of the way an old cassette recorder would record your voice if you had the mic too close to your mouth. Hauppauge has since sent me a registry patch to fix this problem for future recordings, but I really want to clean up the audio on these games if possible. Does anyone know of an easy-to-use audio editor with a filter I can run these mpg files through to clean up the sound? Thx.
Results 1 to 11 of 11
Short of running it through the $200.00 Sonic Foundry/Sony /clipped peak restoration plugin, the answer is "not much". When the source is bad, the result is bad. At least there are a few more games left of the season.
Originally Posted by brownstem
Thanks, everyone, much appreciated. Junkmalle, I'll post the patch later today when I get a chance. Alternatively, I could email it to you.
Here it is:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Conexant\Parameters\ivac15\DrvUSB]
"PreScale_Scart_EXT"=dword:00001000 -
Thanks, Brownstem. That's interesting because a lot of people with the PVR-150 are having problems with audio that's too loud and distorted. Maybe this will work for them.
OK, so I've got Goldwave installed, and I run my mpg file through the Noise Reduction filter (just as a first go, seems an obvious choice). It runs, then when I try to save the file it tells me that it can't save in the original file format, and prompts me with mp3, wav, etc. as choices. Anyone know how/if I can get it to save as an mpg file? I'm not extracting audio, just trying to edit the audio inside the mpg, and I really don't want to have to demux/edit/remux. Thanks.
Man, that would be NICE, but alas, you'll have to save it as a WAV, and ultimately remux it.
Audio Sound Distorted
By Teac23 in forum Software PlayingReplies: 0Last Post: 1st Aug 2010, 07:40 -
How do I clean the noise on video vob file?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2008, 06:40 -
distorted audio
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 20th Mar 2008, 14:11 -
Clean up audio on AVI file
By marybutts in forum AudioReplies: 2Last Post: 11th Jan 2008, 06:15 -
WMP10 - why this distorted MPG?
By terrypin in forum Newbie / General discussionsReplies: 16Last Post: 14th Nov 2007, 07:16
