i just installed version2 beta8 of svcd. all seems to work great. the one problem i am having is that i'm unable to view the "set the menu tv standard" at the bottom of the settings in menu. i want to change it to ntsc to make sure my menu plays it that way, but i'm not able to do that because the screen cuts off at the bottom. anybody else notice this oddity. it also cuts off at the process screen for the selection of "set pan scan info". any suggestions.
What is your screen resolution?
it was the screen resolution. i had it at 800*600. i bumped it to 1024. thanks for pointing that out. i love your program.
I shall try to make it more friendly to 800*600....
I have the same problem on RC1. I am using an XtasyEverything card directly to a TV. The maximum resolution I have available to use is 800x600. I changed the TV Standard in the registry, but its still very difficult to use when I cannot resize the main dialog so it fits in the 800x600. The dialog also overlaid the windows taskbar. I could not get to it until I moved the main dialog a little. The issue will be primarily for those of us using only a TV out, where even 800x600 is pushing the edge of discernable type. I have been able to use it by waiting until just before the dialog comes up, clicking on the explorer window so that SVCD2DVD comes up behind the explorer, so I can drag the files. If I do it too early I get an error (shown below) that is persistant until I reboot.
I also use it on a Haupagge PVR350 system without the 800x600 limitation, and it works very nicely (I mean I love it!). I do get the same startup error there occasionally without trying to bring it up in the background).
Version: 2.0 RC1
Type: System.NullReferenceException
Source: Interop.CodeLock
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at CodeLock._Secure.Authenticate(String pass)
at AxCodeLock.AxSecure.Authenticate(String pass)
at x3284ccece41ee22b.x210ff09a2516b1a7.x41f470203acc6 a6e()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426) -
I have begun some work in making it more 800*600 friendly. The main problem is that the menu designer requires a certain size (without scaling) - but i will get there.
BTW you don't have to use Explorer to load up assets, you can use the "browse" button on the assets bar too...SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 02:50 -
MENU Settings / new DVDFLICK
By mrlewp in forum Authoring (VCD/SVCD)Replies: 1Last Post: 14th Jul 2011, 10:20 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
