I have a video clip with ac3 audio I saved it as a wav file with the video separate using virtualdub, but am not quite sure if I did it correctly, because I tried headache and the response is no codec is available to encode and decode but there must be cos I downloaded lame razor. I used to know what to do but I've completely forgotten. Can u help. Thanks
Results 1 to 13 of 13
Look to the left under Guides or click below
https://www.videohelp.com/tools?toolsearch=&s=&orderby=Name&hits=50&convert=AC3+to+MP3&...+or+List+tools -
I have some of those tools but I am not clear of the procedure on how you save the wav file using virtualdub. Do u save it as a wav file or .wav or .ac3 .mp3 (all files) in order to be able to convert. This I tried and it did not work. The response was no codec available like I mentioned before.
Is your video clip from a DVD or an avi with ac3 audio? If its the latter you may need to run it through AC3Fix first.......
.....as for HeadAC3he..it a great conversion tool BUT ensure you have ALL the .dll's for your system or you'll never get it to work....get them here (you may need to turn off any add blockers/firewalls/proxies to get in if you just get a few +'s....)
http://mitglied.lycos.de/darkav/ -
"I think" well IS IT OR ISNT IT....jeeezuz I'm not asking you to come up with a theory for evolution.
Forgive me monzie for rocking your boat this is because I am new at all this and it doesn't come as second nature like to some, that's why I said I suppose it must be as the resampling was 48000hz. What would that imply?
We all start as newies OK (me too about a year ago).........but you must know what your source is... is it from a rip ie a (read your) DVD or an avi (read you downloaded it)?...so which is it?
A good old Anglo -Saxon term (legitamate english) is:
WANKER
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Cobra
***Warning expired*** -
monzie - if you don't like it, just leave. No need for that sort of behaviour.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 20:05 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 15:12 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 22:52 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 26th Aug 2008, 00:59
