I'm using IE 6.0.2800. Today I have had this wierd problem. I can get on some sites but not others. It's totally driving me nuts. I can get on sites like excite, hotmail, this one, and others. But I can't get on Ask.com, my locla weather station, dogpile, and I am even unable to get on my routers webpage....and many others. what could be causing this insane problem?
What We Do In Life, Echoes In Eternity....
Doesn't sound like it's on your side. More than likely, there's a bad router on the internet on your path to Ask.Com. You can rule out DNS server problems by entering http://65.214.39.7
I just did a Tracert to ASK.COM and discovered a bad router along the path. I'm sure they'll fix it soon.
You can also download http://winmtr.sourceforge.net/winmtr_bin.zip
That will show you the bad router along your path. -
yeah but what about the 20 other sites i tried that don't work....most of them are from my favorites. half of them work half don't?
Your link worked and ask poppped up. but if I type ask in , no server found?
FUSTRATING!!What We Do In Life, Echoes In Eternity.... -
AHA ! Sounds like the DNS server is having problems resolving.
In THAT case, under your network settings, add the following address to your list of DNS servers (it's in TCP/IP config)
4.2.2.2
That's a very fast DNS server out there. It should help. -
The problem is I can't even get on the router page to change or see settings
i've rebooted pc, havne't rebooted router.......will now, though don't know why that slipped my mind
Recording Stream on local computer : Streaming Server Wowza Media Server 2
By iLove in forum Video Streaming DownloadingReplies: 2Last Post: 19th Apr 2012, 16:25 -
How to find what programs connect to internet
By Tbag in forum ComputerReplies: 28Last Post: 10th Jul 2011, 15:29 -
Scenarist Mux Server Problem...Anyone?
By Thommers in forum Authoring (Blu-ray)Replies: 4Last Post: 11th Jun 2009, 13:06 -
Problem downloading Stopzilla updates -- Server keeps timing out
By JudgeGarth in forum ComputerReplies: 3Last Post: 24th Apr 2009, 11:37 -
install Win2008 Server STD Government Volume License on Server with no O/S
By retroborg in forum ComputerReplies: 5Last Post: 11th Nov 2008, 09:18
