Results 1 to 10 of 10
  1. I have been at this for a little bit now but I can not seem to back up 2 of my new movies that i am having a problem with. they both are doing the same thing. Little black book and the forgotten. everytime i try and use DVD Shrink to back them up they both get to a certian percentage of reading for the first stage to determine the ammount of commpression and then it locks up and then it has a redundence error. cansomeone help me out.
    thanks,
    nathan
    AIM- grandrapidsbest
    nextlevel@tmailcom
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Rip with the newest dvddecrypter.
    It is version 3.5.2.0
  3. Member wulf109's Avatar
    Jul 2002
    They use a new copy protection DVD Shrink cannot break. You need to rip them to your HD first with the new version of DVD Decrypter 3.5.2 which is capable of breaking the new copy protection. Once on our HD you will be able to copy with DVD Shrink.
  4. when im done using dvd decrypter 3.5.2, then how do i use dvd shrink?
  5. Banned
    Sep 2004
    Select open files and then direct shrink to where decrypter ripped the files and then select the folder and then shrink
  6. Banned
    Sep 2004
    No problem
  7. I am now getting a error from DVD Decrypter that says
    W 18:19:51 Arrrrgggh! Too Many 'Pack Header Not Found' Errors!
    any ideas???
  8. Banned
    Sep 2004
    Take a screen capture of the error log and post it here.
    We could then help you more.
