I am trying to set up my Sky (NTL) system so I can record on my hard drive etc. I have AverTV DBT as my capture card but am a little unsure as to what to connect. I have a lead (yellow) that comes out of a video in/out port but this is far too short to reach my TV. I have also got hold of a 5m cable which can run from my TV consisting of a plug that goes in the back of my PC (This will go into video or video in/out I think. This cable also has black and red jacks if this helps.Included with this set of leads is a Scart socket which can switch between Input and Output and there are also connections for Audio L and R , S Video and Video. My PC also has an antenna socket but I don't think this needs anything.
This probably sounds totally confusing but I was told I have got the correct cables but am unsure where everything plugs in. I am just looking for some advice/ diagrams.
The lead I was on about consists of :
1 x Switchable scart adptor with Audio left & right RCA connectors, S Video / Video composite connector.
1 x S Video Male - Male cable 5m
1 x 3.5mm Stereo Plug male - 2 x RCA phono pugs male cable 5m
Hopefully this may make a little more sense than my previous waffling post! -
Scart adapter into TV or sky box.
Set switch on scart adapter to OUT
2 RCA (As you're in the UK, we call them phono) to red and white sockets on scart adapter.
Other end (3.5mm plug) to audio in on your AverTV card if it has one, if it doesn't, use the LINE IN on your sound card.
At this point you should be able to hear TV sound on your pc. If not, play around with the settings in your Windows Mixer.
S-Video lead into S-Video (mini-DIN) socket in scart adapter (if it has one), other end into S-Video socket in AverTV card (if it has one). If you don't have S-Video at one end or another, you'll need a phono to phono lead to go between the yellow socket on your scart adapter and the yellow phono on the AverTV.
That should now give you video too! -
I have my system working perfectly now. Well almost! There is no sound on recordings so what will I need to alter?
Newbie needs some advice - capture card so I can record several cameras?
By wiemos in forum Capturing and VCRReplies: 4Last Post: 19th May 2011, 03:41 -
What to look for in Video Capture/Software 4 newbie?
By rivrbyte in forum Newbie / General discussionsReplies: 16Last Post: 1st Mar 2010, 14:42 -
Newbie wanting to capture/re-author DVD from old and new sources...
By archaic0 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2009, 17:49 -
Newbie frame/ field - capture both interlaced fields
By peter bradbeer in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 8th Feb 2008, 15:36 -
Capture in segments...help for newbie!!
By wormdog88 in forum Capturing and VCRReplies: 0Last Post: 10th May 2007, 08:37
