Oh well maybe I was just lucky and got one of the remaining DVD's in stock, there has to be some other use for the DVD other than just upgrading the hard drive, Pioneer did say to me today that they have no method of upgrading the firmware on the existing DVD to make it more compatible with the newer media, however there is formware for the the A07 on the web site if the drive were attached to a PC....... Anyone wanna toss a coin?
HB
Results 121 to 150 of 919
I bet IF you do that it will no longer recognize the burner. But the worst part for you would be you won't be able to flash it back. Because the firmware contained in the burner in the machine is very different from that used on the pc types.
IF your actually going to try it, and I wouldn't recommend you do so.
The first thing I'd do would be to place it into your pc and then run a third party firmware backup program, so that you'll atleast have the original firmware it contained, because you can't d/l that firmware anywhere on the net, they simply don't update it like they do on pc's and it's *not* the same. IF you mess up, you'll wind up buying a new burner from a service center, and it will cost you $$$; unlike buying a burner off the shelf. Best bet it to *not* mess with the burner. YES it's true *all* the service dvd is for, is to change out the hd; remember, it really isn't a consumer part, rather it's for service centers, just like the service remote, all it's for is service; it's not a consumer part.
The fact that we can get our hands on the service dvd, doesn't change what it's for; sorry.
Originally Posted by Hobgoblin -
OK! I have finally sourced the DVD and the remote for the weekend and have a 300GB disk to hand. However, I need clarification of the instructions before I screw things up. The instructions I have from this posting are as follows:
1.Change HD
2. Power ON
3.Confirmation of the CPRM ID No. as follows: press ESC then STEREO, take a note of the 9 digit number, you will need it later( same No. is on the back of recorder), Exit this mode by pressing CLEAR.
4.Deletion of the CPRM ID No.: press ESC + STEREO, input the same number as the ID number and press STOP.
5. Input of the CPRM ID No. and ID data: press ESC+STEREO, input 9-digit ID number then press SEARCH to register ID, after this recorder's display indicates "INSERT ID", open drawer with recorder's OPEN/CLOSE button and insert ID disc, close. After recorder's display indicates "ID DATA OK" press CLEAR button.
Do it at your own risk! I did.
Same exact procedure with units DVD drive. Forgot to mention, after step 5 power down then up, go to recorder's menu and initialize disc!!! ID disc is Pioneer part #GGV1179, it's a 2GB DVD disc non Windows format!
I am ok for 1 and 2. Part 3 will give me something like 123456789. It's after this that things get a bit iffy as there is references to CPRM IDs and IDs. Part 3 gives me the CPRM ID. Does part 4 mean to enter this same number in again? At part 5, do I now enter the same 9 digit number again, hit search and it will then prompt for the data disc? I then power it down and then up again. Will I now be prompted to initialize the disc or do I have to select it from some menu? I have to get this right first time, hence the clarification. -
Hi everyone.
I have a 720 Pioneer new, and have mot started using the hard drive yet.
I too want to intstall a 250, 300, or 400Gb drive. Am trying to get the Pioneer image but its a pain via that m* train, only 40 % so far after weeks.
What about uising a hex editor on the hard drive to see where this ID is stored, clone to new and re-edit. Surely that is possible ?
Any comments ?
Wysiwig -
Noop new HD = new ID info needed, that's the whole purpose of the ID Disk.
Originally Posted by WYSIWYSI -
I know that, from the info in posts above thanks
If you clone your drive and use a hex editor to alter the ID , whats the fuss all about . Its no different than using a service disk except that does it for you. Surely you can see that ?
Wysiwig -
OK then say you do clone your disk which isn't in windows format, then you go to edit the ID number; where are you going to get the proper new number from for the new HD?
Unless I misunderstood, I thought the ID number was derived from the Recorders ID and hence the marying of Drive specific to that DVD recorder, All I think the Pioneer Disc does is to initialise by special non DOS format with ID embedded from the machines built in ID chip. Someone wrote that its derived from the number on the rear plate.
Its not an issue if Disc isn't in windows format because a hex editor can edit any format or hard drive.
Alternatively I can c;one my existinng virgin bare Pioneer drive to another of same size and that will transport the ID with it too, so then I can have a ddy based external Hard drive system, which I am doing just that on my Pace twin Tuner PVR , and am using 3.5" drives.
Any input to say whether its a false trail would be welcome.
Wysiwig -
Correction: --
Alternatively I can clone my existinng virgin bare Pioneer drive to another of same size and that will transport the ID with it too, so then I can have a caddy based external Hard drive system, which I am doing just that on my Pace twin Tuner PVR , and am using 3.5" drives.
Sorry for mistakes
Wysiwys
Further to my earlier posting, I gave up waiting for clarification of the instructions and decided to try and upgrade the hard disk. After 30 minutes of nerve wracking activity (the machine is only 2 months old!), I now have a 300GB DVR520, which gives me 131 hours in SP mode. The instructions are pretty much OK, but could have been a bit clearer.
1.Change HD
2. Power ON (you will get an error message on screen about hardware - Don't panic at this stage)
4.Deletion of the CPRM ID No.: press ESC + STEREO, input the same number as the ID number and press STOP (this happens on the LED display, not on the TV).
5. Input of the CPRM ID No. and ID data: press ESC+STEREO, input 9-digit ID number (again, this is on the LED display) then press SEARCH to register ID, after this recorder's display indicates "INSERT ID", open drawer with recorder's OPEN/CLOSE button and insert ID disc, close. After recorder's display indicates "ID DATA OK" press CLEAR button.
6. Power down and then up again. Go to setup menu and initialise drive. -
Hi Canon10D,Originally Posted by canon10d
Many thanks for your kindly information. I am happy to hear someone have sucessful upgrade their HD. I have the Pioneer 5100H and would like to upgrade to 300GB as well. I Think You are in UK as well. Can I buy the DVD off you and borrow your "remote"? I will pay the postal cost and deposit for the remote.
I live in Yorkshire near Harrogate. I hope you can help me to upgrade my 2 Pioneer 5100H. Thanks a lot!
Cheers..
-Shing- -
Shing
I don't honestly know if you can upgrade the 5100H in the same way as the 520, as I have no knowledge of it. I am still debating what to do with the DVD and the remote, not to mention the 80GB drive. Part of me says sell them and recoup at least some of the cost (and they are costly here in the UK), and part of me says keep them just in case the new drive fails or an even bigger drive appears and I want to put that in. I will PM you about them. -
Hi Canon10d
I too am in UK, and would also welcome an opportunity to do a deal or whatever too, or maybe help us both. I am in the Midlands.
My machine is 720, am still finding instructions ambiguous
1.Change HD
4.Deletion of the CPRM ID No.: press ESC + STEREO, input the same number as the ID number and press STOP (this happens on the LED display, not on the TV). 5. Input of the CPRM ID No. and ID data: press ESC+STEREO, input 9-digit ID number (again, this is on the LED display) then press SEARCH to register ID, after this recorder's display indicates "INSERT ID", open drawer with recorder's OPEN/CLOSE button and insert ID disc, close. After recorder's display indicates "ID DATA OK" press CLEAR button.
Why do we need to delete ?
Did you not have to use a PSIOn or whatever ? was it just Pioneer disk ? and IR remote used ?
Hope to hear any suggestions etc for the disc or whatever may be possible
thanks a mill
WYSIWYS -
Hi,
I would like to report that my Pioneer 5100H (UK model) has been sucessful upgraded with a Maxtore diamond 10 ATA 300GB hard disk with the member of this forum and information they posted. I am going to upgrade my other 5100H in a few days.
Thanks to all who are kindly to share their sucess information!
All the best !
Nonfee -
Has anyone successfully installed this template to their Palm? I cannot seem to install it on my PalmIIIx.Originally Posted by steve2713
I used a ProntoCVnt to convert the "Service" program kindly upload by robke51 to a *.dbd file, but I cannot seem to install it into my Palm IIIx. What am I doing wrong?
I assume you mean a pdb file. Have you tried loading the pdb in the Remote program? Or are you actually not able to install the pdb on the Palm?Originally Posted by Treesmaker
First I converted the ccf file into a pdb file then I uploaded it to my Palm Desktop software on my computer to be syn. After syn my palm on the craddle I get this error message in the log " HotSync operation started 06/07/05 21:20:05
- Invalid handheld file deleted: C:\Program Files\palmOne\RG\Install\ProntoCnvt.PDB"
I am using a Palm IIIx with 8mb. This is a monochrome model.
After the syn, I cannot find the remote anywhere on my Palm. Please tell me what I am doing wrong, TIA. -
Hi Treemaker,Originally Posted by Treesmaker
I just got the Handspring Palm Visor delux from the car boot sale. I think it works just like Palm IIIx.
You have to copy your remote program(OmniRemote) and converted ProntoCnvt.pdb into the ADD-ON directory. Open the Plam desktop, click the "Install" icon and "add" the remote program & the ProntoCnvt.pdb. Click "Done" when finish.
Next time you syn your Palm, the remote program should be automatic installed into your palm.
On your palm Main menu(All), you should see the OmniRemote icon. Open the program and click the "OmniRemote pro" (on the left top screen). Selected the "Advanced" from the drop down menu. Then, select the "databases" to load the Pronto template. Remember to scale to your screen size when you convert the Pronto.ccf.
Hope this would help!
Nonfee. -
Hi, thanks a million for your kind help. I am almost there. I can see 1 button. I think I used the wrong size ie 320x320 when converting. What size size shall I choose for my Palm IIIX ?
TIA
hello everyone, how to convert the service.ccf to service.pdb? using this ProntoCnvt.PDB ? or else?
If anyone in the UK is interested, I can loan out the service remote and DVD so that you can upgrade the hard disk.
Send me a PM for details. -
Originally Posted by harly
Yes, I successfully transfered this program onto my Palm. I can see all the keys, and I have tested 3 buttons and it seems to work.
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Hard Drive upgrade for Pioneer DVR-530/630H
By Hkan in forum DVD & Blu-ray RecordersReplies: 55Last Post: 22nd Aug 2012, 02:07 -
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 09:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26
