How can I determine what the format of downloaded videos is?
Well if they end in .mov, they're quicktime. If they end in .mpg, they're mpeg...
Oh wait, you meant BEYOND that?
Well, a lot of us use GSpot.
http://gspot.headbands.com
There are other tools, check the tools section. -
If you are worrying about play back on your PC Gordian Knot codec pack will let you play anything don't need to worry about video type. But if you need to know use a tool.
OK I was wrong stay away unless ypu know you have many codec that you need. Or just stay away from codec packs. (but really I have had no problems, but thats just me. not a big enough sample to judge effectiveness of codec packs.) -
Codec Packs are the work of Satan's minions here on the mortal plane.
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 17:52 -
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
Are there different types of S video cables or is it all standard?
By PunkMaister in forum Capturing and VCRReplies: 6Last Post: 10th Jan 2009, 20:47 -
Types of Video Formats
By christopherm in forum Newbie / General discussionsReplies: 5Last Post: 18th Mar 2008, 20:48 -
All video types to standard size / format?
By fuzzyvideomunster in forum Video ConversionReplies: 2Last Post: 3rd Jul 2007, 11:50
