well here's the deal I bought a movie and there's no option to take off the commentary can this be done. Also since the commentary a higher volume then the backround how would i boost the backround noise after i take out the commentary. ANY QUESTIONS LET ME KNOW!
It's the M-O-N-O and I can't even spell the rest, it takes too long and I need another cigarette, I can't hear my right ear is mad wack, so stfu and listen or get an ass kickin
Or is that asking too much.... -
Just push the Audio button on your Remote Control.
Usually the audio channels arwe selectable using your remote.
What DVD is it giving you problems?snappy phrase
I don't know what you're talking about. -
Kgonepostl - you need to go to where you can select various types of audio (like normally if you hit the info button, it'll display on screen the controls for your DVD player). Now, simply change the audio. (What movie is this? Chances are - there is more than one english audio track...commonly there is a 2 channel, a 5.1 channel, and the directors commentary. By switching it to either 5.1, or 2.0 channel, you should turn it off. (Directories commentary is almost always 2 channel as well, just FYI.))
:star: :star: :star: :star:
Archived DVD Scans
Nero V ImgTools V Decrypter
:star: :star: :star: :star: -
This is a real underground movie. It's called Juggalo Championshit wrestling. any advice at trying to use it with a playstation 2? its an original copy, so its fine.
thx for the info btw fandim, i recently decided to actually BUY dvd's instead of ripping off industry's so i'm kinda new to the whole conceptIt's the M-O-N-O and I can't even spell the rest, it takes too long and I need another cigarette, I can't hear my right ear is mad wack, so stfu and listen or get an ass kickin -
lol, ya of course you got it your a hatchetman for christ sake. JUGGALO!
Get rid of Directors Commentary using Demux?
By Bushy162 in forum DVD RippingReplies: 3Last Post: 11th Jul 2011, 06:24 -
Audio Commentary
By Anonymous234 in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2009, 20:02 -
Commentary track
By AlanHK in forum AudioReplies: 10Last Post: 6th Nov 2008, 02:47 -
How Can You Tell which one(s) are the directors commentary
By jah711 in forum Blu-ray RippingReplies: 1Last Post: 25th Aug 2008, 01:00 -
commentary
By tylerdurden in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 16:45
