Hi!
Got a small prob. I lend my dad a cupple of vcd to try on he´s new Widescreen tv (Pal). And I found a problem, some of my vcd´s did not work correcly. we culldent make the "black stripes" go away.
So what are the correct configuration in tempgenc ?
I want my vcd to work on a 4:3 tv and a widescreen.
Regards,
Magnus
/Sweden)
A widescreen TV is always 16:9. So if your VCD contains 2.x:1 (there are several formats) widescreen material, you will have black bars on the top and bottom. Some TVs have additional zoom modes which can make the black bars disappear, but they do this by shrinking/expanding/cropping the image, so a purist like me wouldn't use them.
check your dads tv and see if under setting you cannot change the format to 4:3, if you can, that may fix the problem
Sony Vegas Widescreen Problem
By Quackulator in forum EditingReplies: 3Last Post: 20th Apr 2010, 20:12 -
Mp4 / H.264 / widescreen problem
By mrjoetoff in forum Newbie / General discussionsReplies: 13Last Post: 23rd Aug 2009, 11:05 -
Widescreen Problem When Capturing
By DW in forum Capturing and VCRReplies: 4Last Post: 26th Mar 2009, 06:46 -
widescreen dvd problem
By seanin in forum MacReplies: 2Last Post: 6th Jan 2009, 19:25 -
Vegas render to 16:9 widescreen problem
By EMPERORelement in forum EditingReplies: 10Last Post: 19th May 2007, 17:32
