I am trying to capture NTSC video into virtualdub but I keep getting frame drops; max of about 20 in 40 minutes. I'm using a matrox x10 to capture .
Specs you may need
Asus PC-DL Deluxe
2x 2.8 xeon
1gig Corsair twinx (low latencey)
SB audigy 2zs
250Gb WD 7200rpm
thanks
Adobe Premiere Pro comes with the X10 suite -- you should be using that , not v-dub ..
and set up your hard drives as the say ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I like the noise reduction feature on virtual dub for this particular capture help the picture. Beside whenever I try using capture in premiere, aborting/end the capture always ends in premiere freezing up
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 11:36 -
Analog capture with Studio Pinnacle 15HD, Dropped frames?
By rivrbyte in forum Capturing and VCRReplies: 2Last Post: 31st Dec 2011, 15:00 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
System dropping frames because it's getting old?
By quanz in forum Capturing and VCRReplies: 16Last Post: 30th Nov 2009, 06:20 -
Hauppage WinTV, BTWinCap to Vdub, dropping frames
By elvisish in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 11:03
