I would like to know what is the fastest burn speed which I can safely burn backups of my movie DVDs. Will using faster burn speeds affect the read/play reliability of the backup DVD Movie?
I am using the Plextor 708A Burner with Tayio Yuden DVD-R, buring at 4X (with Nero.) I'd like to replace this DVD writer to take advantage of faster burn speeds (8X or higher), using TY DVD-R media.
Can you offer any suggestions as to which drives and media combination will burn DVD movies at speeds 8x or higher, without compromising write/read/play reliability?
Thank you![]()
The 708A will do 8x. With a faster burner, you could achieve 16x burns with TYG02 reliably. 12x with a couple other medias, but 8x is the safest bet for most medias. Plus, you'll usually need a hacked firmware to write faster than the disc manufacturers rated speed.
< The 708A will do 8x. >
Are you saying that the Plextor 708A burns at 8X speed with DVD-R media?
Nero shows 4x as the fastest burn speed using TY DVD-R with my Plextor.
I have burned DVD+R media at 8X with the Plextor, but I want to stick with DVD-R. -
4x -R, 8x +R, oh yeah, that's right, sorry
there must be a patched firmware out there somewhere
good Plextor forum -
Burn speeds shouldnt affect quality. Assuming of course your pc is fast enough or you aren't surfing, playing mp3's and running emule all at the same time.
Google is your Friend -
Your Plextor comes with a nice tool to test this; in Plextools use the PI/POF test to compare burns at different speed.
All I can say is that my 712 really likes burning 4x -R Maxells, I get less than 50kB on the PI, 0 POF and there's hardly any blue on the graph. -
nic2k4 wrote:
Plextools can only do PI/PO scans with the 712A & 716A drives......it can not be done with the 708A drive......for the 708A drive Plextools is good for BITSETTING to DVD-ROM......Your Plextor comes with a nice tool to test this; in Plextools use the PI/POF test to compare burns at different speed.
there is no patched firmware to make the 708A drive burn DVD-R @8x speed......you want a faster 8x DVD-R burner then purchase a plextor 712 or a 716, or a pioneer 108 or a benq 1620..........
Conversion errors in dvd slideshow gui during export burn to disc
By outdoorsyisin in forum Authoring (DVD)Replies: 2Last Post: 16th Mar 2012, 12:29 -
What maximum speed to burn DVD I supposed to go with ?
By mahogany in forum Newbie / General discussionsReplies: 3Last Post: 26th Aug 2010, 00:42 -
New here- trying to convert files to burn to DVD using AVStoDVD... errors..
By tressls in forum Authoring (DVD)Replies: 6Last Post: 7th May 2010, 17:25 -
Encoding errors, cannot burn DVD
By Surber in forum Authoring (DVD)Replies: 3Last Post: 8th Apr 2010, 12:55 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 04:22
