I installed TMPGEnc Plus 2.5 on my computer but could find no way to access it. It was not listed in my programs folder nor was there a desktop icon. Is this something you must access through your capture/editing program? I'm confused.
did you download the installer version?
http://www.pegasys-inc.com/en/download/tp.html
some other version may just be a zip file with program. -
If you bought or downloaded it from the pegasys web site it may be in a folder labeled pegasys inc.
It doesn't matter who you vote for. The government always gets in. -
The file I installed from needed to be unzipped. I unzipped and installed. Everything looked right as it was installing, but then, situation above. I will download from the link you provided and try again tonight.Originally Posted by Baldrick
You don't think there's anything I need to "uninstall" to be able to "reinstall" do you seeing as how the program never landed in my programs folder or in my add/remove programs list in my control panel. -
Have not purchased yet, want to check it out first, trying to install the "trial version."Originally Posted by Laddydaddy
Although it's a trial version it had to be installed somewhere. Do a search on your computer or look in in your program folder for the pegasys folder.
Problem installing DVDGUI0948.exe
By ROGUTAH in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2012, 19:17 -
Problem with installing ffmpegX on MacOSX
By wlochatyjoe in forum ffmpegX general discussionReplies: 2Last Post: 11th Feb 2010, 14:06 -
Problem installing Super
By Garibaldi in forum Video ConversionReplies: 7Last Post: 6th Jan 2009, 12:20 -
Strange Problem after installing Kaspersky
By anirban in forum Newbie / General discussionsReplies: 0Last Post: 28th Jul 2008, 11:59 -
Problem Installing Nero 8
By ranchhand in forum ComputerReplies: 1Last Post: 10th Feb 2008, 21:20
