In November 2004 i had ordered 14 packs of Datawrite Grey 8x, I had purchased these in bulk because of their low price and to use in the future.
I have now started using these discs, and i have noticed that then i 'puff' on the writing side a ring can be seen on the outer diameter of the disc (about 1 inch) THIS HAPPEND TO ALL OF THE DISCS WHEN BLANK AND WRITTEN
i have used these discs for a long time and only this time have come across this happening.
can you tell me if these discs i have purchased are actually A grade discs, or were these a rejected batch, overproduction etc?
these discs burn OK, but i have lost trust in them , and have stuck to Verbatim 8X Printables.
Datawrite have lost my trust, one UK website stated "these packs may contain some 4x media" (this was stated next to the Datawrite Grey 8x) i know these discs have been VERY popular, but now thinking about it they are about £6 for 25 discs for a reason, id rather spend more and go for Verbatims
anyone heard of the ring on their UNBURNED media, when they 'puff' on it or when they hold it from the edges (ring forming with the heat from hand)
Thank you,
Results 1 to 1 of 1
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
What's you choice when it come's DVD-R blank media?
By mrjust in forum Off topicReplies: 4Last Post: 24th Mar 2010, 21:24 -
looking for the best site to buy blank media
By hardy in forum MediaReplies: 6Last Post: 3rd Mar 2010, 22:37 -
Blank DVD Media
By jason in forum Newbie / General discussionsReplies: 21Last Post: 2nd Dec 2008, 12:40 -
Blank media revisited
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2008, 10:57
