Hi All,
I want to convert DVD NTSC MPEG2 file to SVCD NTSC MPEG2 file for make SVCD.
Waht are utilities can do it?
Thanks!
Able,
Chinese??? I am! Guess you didn't look through the column on the left, huh? Well, you should, it helps a lot! Try use TMPGEnc. Its one of the best and its FREE!!! Download it here:
http://www.tmpgenc.com/
Jordan -
Hi, Jordan,
Yes, I'm chinese.
How to use TMPGENC to convert MPEG2 file, it show "file not supported" message?
Thank a lot!
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 17:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12 -
Trying to convert MPEG2 file to work in a Philips 5980 DVD player
By JohnWB in forum Video ConversionReplies: 3Last Post: 31st Mar 2008, 08:16 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 13:03
