Hi, all. I'm just staritng to encode some DV and VOB files with VirtualDub and the compression options are Greek to me... Any suggestions on what codec(s) to use for good quality and minimal file size? I know there's no "best", but I'd like your opinions...
Also, if there are specific settings within VD or for a particular codec (in terms of frame rate, etc) that I should adjust, please let me know your thoughts on that as well. Thanks in advance.
J
thirty seconds of shame
http://www.30SoS.com -
Thanks, SatStorm. Never heard of Huffyuv, but have Xvid on my machine now. And no offense on the 'greek' thing -- just saying the codec options might as well be written in a foreign language...
Anyone else wanna toss in their two cents on which codec is 'the best'?
Jthirty seconds of shame
For low quality, I use DivX mpeg4, at highest quality settings.
For high quality, I use HuffYUV.Cheers, Jim
My DVDLab Guides -
If you are using DV as you say, the Panasonic DV Codec will enable you to decode and encode to DV using Virtualdub. Gives you a smaller file size than HuffyUV too.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
MJPEG is good
XviD is the best, 'nuff said.
Best of all my DVD player can play it.(Philips DVP642)
XviD 2-Pass VBR with VBR audio on a single CD is breathtaking on my 53" TV.
A few questions regarding quality, file size, etc...
By smackyourfupa in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2010, 07:11 -
Bitrate/QC same file size, is quality the same?
By marioval in forum DVD RippingReplies: 1Last Post: 4th Nov 2010, 08:56 -
Quality and File Size for TV Show Ripping
By Johnbil in forum DVD RippingReplies: 8Last Post: 24th Sep 2010, 19:34 -
Best Video Format/Codec For Small Size, Yet Low Loss In Quality?
By kiwisoup in forum Video ConversionReplies: 13Last Post: 27th Jul 2010, 10:01 -
MPEG-2 video quality by file size?
By 3lutz3toe in forum MacReplies: 1Last Post: 27th Jun 2007, 18:17
