Hi all!
Im tring to backup my original DVD movie!
DVD X Copy platinum says "Error while reading. I/O problem".
DVD Decrypter says my device, the Sony DRU 500 2.1a (ATA): "Media region is mismatched to logical unit region.
DVD shrink says i have to change the region code on my Sony. How do i do that and can i make it region free instead?
Whats the solution to backup my discs from all over world?
Do I need to make my Sony DVD-ROM region free or/and how do I do that?
regards Thomas
Go to the Tools section over on the left and look at "Region Free Tools".
You need either AnyDVD or DVD Region-Free. -
No big deal
It will still rip using dvddecrypter or dvdshrink.
I have ripped region 2 discs b4 and I live in region 1.
Just rip away -
thombytor,
next time, just unselect the display the region mismatch message option in dvddecrypter.
Thank you bazooka for posting that information. I just made a backup copy of my region-3 dvd movie using generic region-1 dvd r/rw 4x dual with DVD Decrypter 3.5 and DVDShrink 3.2.Originally Posted by bazooka
DVD Region-Free software is not needed to backup my region-3 movies with my computer's region-1 dvd r/rw 4x dual, DVD_Decrypter and DVDShrink. Thanks again!
DVD backup : are they region free ?
By black cloud in forum DVD RippingReplies: 4Last Post: 21st Mar 2010, 22:55 -
how can i find the region code of a backup and if its ntsc/pal
By korazy in forum DVD RippingReplies: 4Last Post: 26th Dec 2008, 23:10 -
Problem making backup of The Dark Knight Region 2 DVD
By soneman in forum DVD RippingReplies: 4Last Post: 14th Dec 2008, 16:48 -
region 2 dvd doesn't work with media player classic
By clamchowder01 in forum Software PlayingReplies: 5Last Post: 17th Oct 2008, 23:27 -
Region1 disc... need to backup to region 0
By snadge in forum DVD RippingReplies: 11Last Post: 1st Mar 2008, 14:25
