Hi i have a Provideo PV-231 and use the software of my card to capture in vcd format. (th card is the same as grandtec vcd 2000 plus).
The hardware MPEG-1 encoder chip is Winbond W99200F.
When I capture in VCD format I have sometimes pixelization also in static scenes. I just used registry settings of Steve kittelsen.
Is there another compatible software for my mpeg-1 capture card or other registry settings to make my card capture better quality?
The card is documented here:
https://www.videohelp.com/capturecards.php?CaptureCard=pv-231&Submit=Search&searchconne...&Search=Search
this is the same:
https://www.videohelp.com/capturecards.php?CaptureCardRead=115#comments
there are also other same cards with this excellent mpeg-1 chip.
thanks!
Video Capture Help - Card/Software/Format
By rancineb in forum Capturing and VCRReplies: 3Last Post: 4th Aug 2011, 14:52 -
Trying to select PVR software for my capture card.
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 14th Apr 2010, 19:03 -
From VHS to Capture Card to Capturing Software
By TV107 in forum Capturing and VCRReplies: 1Last Post: 9th Nov 2008, 19:35 -
Question about software for K-World Video Capture Card
By cooper101 in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2007, 14:49 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
