  1. Hi,
    I cant seem to find any information regarding the drive i dont even knwo speeds of drive. ACn anyone enlighten me with any information?
    Mar 2003
    Sweden/Norway
    I would also like some info on this drive.
    I use CloneCD 5.2.6.1... and when I try to burn to CD (Brand: Intenso) I get writing failed!
    Is it possible to upgrade firmware on my Matshita UJ-831D ?
    (I´ve read that its really a Panasonic drive)
  3. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    I don't own that drive, but I can tell you it is just a slim line (Laptop) DVD Recorder made by Panasonic.
    Try this for some help.
    http://forum.rpc1.org/viewtopic.php?t=31370&highlight=Matshita++831D
    Mar 2003
    Sweden/Norway
    Thank you for posting.
    Found out that A LOT of other people have the same problem.
    Also found this link: http://club.cdfreaks.com/showthread.php?t=99194
    From now on.. I really don't know which laptop brand to choose.. Is there any laptop with Plextor writers ?
  5. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    If I had to use a laptop, I'd opt for an external drive, or network it to my desktop, and burn from there.
    You could try one of these
    http://www.newegg.com/Product/ProductList.asp?Manufactory=&PropertyCodeValue=365%3A867...ubmit=Property
    Mar 2003
    Sweden/Norway
    I found at that CloneCD does not work with my DVD/CD-writer.
    Workaround:
    I used UltraISO to transfer all images from CloneCD format -> BIN/Cue format.
    Then I burned the images with Nero.
