  1. Start: 19.01.2005 08:52:48
    End: 19.01.2005 08:52:48
    Dealing time: 00:00:00
    E:\Shrek2\xxxxxxxx.mpg
    Format: Super Video-CD NTSC Film (MPEG-2 480x480 23.976fps VBR 2091kbps, Layer-2 44100Hz 224kbps)
    Video: E:\xxxx\b-2ws.avi
    Audio: E:\xxxx\b-2ws.avi
    Result: Read error occurred at address 00013519 of module 'TMPGEnc.exe' with 2065682C
    never had this happen, what could it be?
  2. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Restart your computer. I've had it say that it cant output some files that it should, too, similar to this error. Restarting my computer, or sometimes even just closing, and re-opening TMPG has solved it. You're using 3.0 XPress, right?
    Seth
    :star: :star: :star: :star:
    Archived DVD Scans
    Nero V ImgTools V Decrypter
  3. Using TMPGENC 2.5 plus with winxp sp2...
  4. Originally Posted by Fandim
    Seth
    Got the same problem this morning, so I don't think it's a matter of rebooting...
  5. losing hope here, tried reinstalling the software, and I still get the same problem. anyone know how to help?
  6. Member BrainStorm69's Avatar
    Aug 2002
    Texas, USA
    Are you overclocking any of your hardware? If so, try setting it back to its rated speed and try again.
