First off, I'm a newbie, so if I'm in the wrong place, please forgive me...
I purchased some DVD's from Europe which are in PAL format, and they won't play in my Panasonic DVD player. They do, however, play in my Apple Computer DVD player. Is there a way to convert or burn somehow, so they will play in my Panasonic DVD player? I tried using DVD Backup program and Toast to burn a copy, but it didn't work. I also have DVD2OneX... but I don't see anything in there that might help.
If anyone has any suggestions that would be awesome.
Thanks!
You are not in th wrong place, but you could try a few simple searches before asking a question that gets asked at least a couple of times a week. I would start by checking out the guides under [b[How To[/b] on your left. The guides under Convert are a good place to start.
Format conversion can take time to get a good result. If buying PAL dvds is something you think you will continue to do, you are better of buying a DVD player that will play PAL disks. A lot less hassle in the long run.Read my blog here.
A couple of posts with useful suggestions to your exact same question is in this inexplicably locked down thread: https://www.videohelp.com/forum/viewtopic.php?t=253892Originally Posted by ssprod
MPEG2Works will do it.
http://www.macupdate.com/info.php/id/12715
http://www.mpeg2works.com/
$10 shareware (i paid)
forum here:
http://www.mpeg2works.com/phpBB2/viewforum.php?f=2
this question is asked repeatedly over there, too.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
Newbie : How to convert PAL into NTSC Format for Video Cassette Player
By kato2010 in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2010, 11:40 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2007, 00:26
