I'm trying out TMPGEnc XPress trial version and am noticing a problem when I pick an avi to convert to mpeg.
Every avi I select, whether the frame rate is 23.976, 29.97, or 25fps, shows up in the clip info screen as 30fps. And the frame rate setting in the advanced clip info is greyed out so I can't change it to the correct frame rate.
I do NOT have this problem in TMPGEnc Plus, only in TMPGEnc XPress.
Is there a way to specify the right frame rate of my source avi's, or is that a feature that only the paid-for version of the program can access?
Thanks,
Results 1 to 1 of 1
tmpgenc xpress auto resize results in 708 width in 720 frame.
By davexnet in forum Video ConversionReplies: 0Last Post: 27th Jan 2010, 13:49 -
Frame Rate (fps)
By PaulBlok in forum Video Streaming DownloadingReplies: 10Last Post: 15th Mar 2009, 09:50 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
