well i just started usin blaze media convert v3.01 for converting videos,making gif's,etc.if i use the the hotkeys for converting the video gets converted.well but when i click on file or edit button proggy crashes.what sud i do?btw can ne1 suggest me some software for converting .wmv to .gif?also i needed some info bout usin which codecs will post details in next post
Sounds like a program bug or conflict with some other program you are using.
For conversions...look in the "How To" section, under "convert".Google is your Friend
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
Blaze - x264 GUI
By Blazeinme in forum Latest Video NewsReplies: 4Last Post: 22nd Sep 2010, 12:52 -
Blaze DVT 2.5a
By 557953 in forum Capturing and VCRReplies: 0Last Post: 2nd Feb 2009, 22:57 -
Blaze HDTV 3.5?
By slats7 in forum DVB / IPTVReplies: 1Last Post: 24th Aug 2008, 23:52 -
*SOLVED* Media problem or workflow problem? (Media problem)
By nosleep in forum Authoring (DVD)Replies: 7Last Post: 2nd Jan 2008, 21:35
