  1. Is there any programs out there that will convert a divx fill right to a dvd video_ts folder with the .vob files and etc, with out having to convert it to a mpeg2 file first and then using all different programs...?
    Thanx,
    Vin
  2. Toast can do this I think... I have the DivX QuickTime plug-in installed.... got it from Divx.com... now I can drag/drop my divx files into Toast and it creates a DVD-Video disc for me no problem.
    I can save as disc image to avoid burning the disc and then copy the video_TS folder off of the disc.
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    toast will be the easiest with drag and drop
    if you are "sauvy" you can use ffmpegx and have it author the video_ts but again, you have to know how to use that app and it can be a little disheartning for those who are not familiar with teh app
    the method i have on my website, which it seems you are referring to, its quite easy and gives you ability to make your own menus
    but toast will work easily
