Hi, I just encoded my first DVD, and when playing on my TV the video is zoomed in a bit. What is the best way to fix the problem? I encoded the video with tmpgenc at the regular aspect ratio.
Thanks for your help!
Is it juust a tiny bit, like maybe 5% missing compared to what you see on the computer screen? It's called overscan, it's normal.
hey thanks for your response. It's definitely overscan... so theres no way of getting rid of it?
The only way to get rid of overscan is to buy a Plasma TV.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
You can add borders with an editor, in other words frame your video. Besides that no.
Of course there is. If you want to go into your service menu on your TV and adjust your settings, mainly HIT & VERT.Originally Posted by akurio
I would advise writing down original settings before adjusting. Most TV's are preset from the factory with TOO much overscan anyway.
But to your question...Yes! -
Even if you do use that solution, which is tricky at best if you don't know what you are doing, you will be doing well if you can get the overscan ratio down below 5%.
Zoomed up picture on PAL DVDs
By Obner in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2007, 17:11
