I having a problem converting this one DivX file to a DVD format currently I have tried using the following Nero6, WinAvi, Cucusoft, Xilisoft and Tmpenc. Each one encodes and burns to a DVD which will play on the computers DVD but not in my stand alone; hopefully someone can point me in right direction on what Im doing wrong.
Thanks in advance
Check your media type (+ or -) against your player.
https://www.videohelp.com/dvdplayersCheers, Jim
My DVDLab Guides -
DVD are -R same as standalone but looked into summary of file I want to convert to dvd I see it is a MPEG layer3, could this be the issue??
it might even be that the standalone you have wont work with - or+ if there not "done" a cetain way.
i have one that wont play stuff unless its been(if its an mpeg) say,demuxed in tmpgenc,then authored with ifoedit,then burned.
you could try vso divxtodvd,its free,and its the only one that lets me play stuff on that problem standalone without using tmpeg,etc.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
Problem converting MKV files with a DTS audio track to DivX
By ryebeena in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2009, 04:31 -
Converting my DVD's to DivX
By noob2 in forum Video ConversionReplies: 2Last Post: 12th Jul 2009, 20:04 -
Problem of jerking in video while Converting DV to DivX / Xvid / DVD
By ckbasak in forum Video ConversionReplies: 7Last Post: 30th Dec 2008, 08:23 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48
