i want to be able to convert some mpegs and stuff to divx in virtualdub. i also want to be able to convert the audio to mpeg layer-3 audio, to keep file sizes down while retaining as much sound quality as possible. however, when i try to convert the audio to mpeg layer-3 in virtualdub, under select audio compression, my choices are limited. my choices range from: 8kBits, 8,000Hz, Mono, but only go as high as: 56kBits, 24,000Hz, Stereo. now, i know that i have seen in a tutorial that you could have much higher kBits and atleast 44,100Hz. so my question is how can i select a higher mpeg layer-3 audio compression in vdub? do i need to install a special codec? thanks in advance.
Install Radium MP3 codec 1.2; download from http://www.doom9.org/Soft21/Files/Audio/ra-codec12.zip.
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 21:25 -
No 48kHz options in MPEG-Layer 3 in VirtualDub and Mod
By ashwin.terminator in forum AudioReplies: 24Last Post: 6th Apr 2009, 14:07 -
Mpeg Layer 3 problems
By ada1984 in forum EditingReplies: 7Last Post: 8th Nov 2007, 21:30 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51 -
MPEG-1 audio Layer 2
By dedine in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 15:51
