I have 5 or 6 simpsons episodes on my computer. All of them are .avi(divx) quality around 175mb each. What I want to do is put these on a dvd and have menus, submenus, perhaps music and video in these menus as well. I am fairly new to this so i need help on converting, authoring and designing menus. If anyone could help it would be greatly appreciated. Just send me to the best how-to guide i guess.
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm can help you with the converting to MPEG-2 part. Then I'd author in TMPGEnc DVD Author using any of the following guides:
http://www.dvd-guides.com/guides.php?category=dvdauthor&name=tmpegencdvdauthor
https://www.videohelp.com/forum/userguides/172123.php
If you want to do anything else, I suggest you sift through both the CONVERT and AUTHOR sections to your left
If in doubt, Google it. -
RT - I should probably give you some friendly advice regarding subject lines.
A lot of members who may be able to help you pass over the subject lines entitles "Help" or "Problem", or the numerous variations upon that theme. You'll get help faster if your subject line is descriptive of the problem.
Also, it helps people who have the same problem search for and find your thread and therefore their solution.
What Jim suggested is a good route to take. Personally, I'd use TMPGEnc to convert them to DVD MPEG-2 and then TMPGEnc DVD Author to make a DVD out of them. TDA (short for TMPGEnc DVD Author) is pretty simple to use, but doesn't give you more sophisticated menu features and so on.
I hope you own the original DVDs to these .AVIs.
Good luck!
Cobra -
He means, he hopes you bought the dvd, because your thread is bordering on warez.Originally Posted by RT
Maybe, but it is unclear.Originally Posted by jimmalenko
That is why I said bordering instead of flat out warez.
Which wall to project on?
By Haopengyou in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2011, 12:27 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Passion Project
By mikedub in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2009, 14:48 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
TeraByte project
By olyteddy in forum Latest Video NewsReplies: 1Last Post: 29th Sep 2007, 00:23
