Hi, all
I burnt a svcd movie and was able to play on Pioneer 343. The problem was that the resume function did not work. If I stop the movie then play again, it starts over from the beginning. I searched on pioneer web site, they said something about the realtime clock counter ... which I have no idea what it is. Furthermore, the player has "last memory" feature which does not work either.
Please tell me what I need to do?
I believe this only applies to music CDs and DVDs. For VCDs and SVCDs, just use pause instead of stop.
A greater expert may be able to provide details, but I believe this has to do with how the VCD is authored. I use ULEAD DVD Movie Factory and have a Pioneer 343. The Resume function works properly with this setup. Try downloading the free trial and give it a whirl.
how can i make sure my dvd will work in any player?
By el_nex in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2009, 18:22 -
make Powerstrip work with MPC-HC WITHOUT using ReClock
By THX-UltraII in forum Media Center PC / MediaCentersReplies: 1Last Post: 12th Feb 2009, 05:44 -
How to make Keep V Flash Converter work
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 30th Nov 2008, 22:29 -
resume partial work done by ffmpegx somehow?
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 25th Jan 2008, 05:19 -
"resume play" feature for dvds burned by dvd recorders (pioneer d
By barninga in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Nov 2007, 03:11
