I have just bought this card and trying to capture my camcorder , i have tried a few settings and software but cant't seem to get good quality. My system is a pentium 2 400Mhz and i have about 5 gig spare to play with. Idealy i want to convert or capture so that i can put them on a cd so that i can play them in my dvd player. I have managed to get a half good picture by using the mpeg 4 codec. Any suggestions.
You'll wanna convert them to vcd later on but to capture you'll need a fast compression codec. I will suggest huffyuv, but to use huffyuv you'll need alot of hd space. you'd be better off using PicVideo MJPEG codec. you can download both of them for free from this site but the PicVideo MJPEG codec leaves a watermark on the video. and the only ways to remove it are to buy the codec for $27 bucks or get a crack from astalavista.com. I use the PicVideo MJpeg codec more often and it uses way less hd space than huffyuv. But huffyuv wont leave a watermark on your video. Hope this helps!
use the following link to download the Pinnacle conversion program Trex.
ftp://ftp.pinnaclesys.de/driver/pc/TRex/TRex.exe
Vertical lines with Pinnacle Studio 14/510 USB card
By karebo in forum Capturing and VCRReplies: 0Last Post: 11th Dec 2011, 16:54 -
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
MP20 Capture Card and Pinnacle Studio 14
By egee17 in forum Capturing and VCRReplies: 0Last Post: 26th Feb 2011, 20:30 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53 -
PCTV Rave Card - trouble capturing xbox + tv audio
By chocolate_brownie in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 09:38
