I've done to the download site and download the zip file, unzip it and it installs a bunch of directories. But there is no setup.exe. The .inf installation says there are files missing.
You need to compile it or download a pre-compiled build as suggested.
I like Gordian Knot, but there may be problems with it.
Gordian Knot has like every codec. and the installers for all.
Are there problems with Gordian Knot? -
Originally Posted by doppletwo
Just get latest DivX and latest XviD video codecs and you'll cover 99% of any AVI video thats being currently used in the world.
Any other codecs needed by some games etc etc are usually installed together with the game itself. -
Thanks for the info. Hasn't caused any problems for me yet though.
THank you again for your reply.snappy phrase
I don't know what you're talking about.
StaxRip XviD Install Guide
By Trac in forum User guidesReplies: 2Last Post: 8th Jun 2013, 01:08 -
Unable to install an XVID codec for 64-bit Windows 7
By catchaat in forum Video Streaming DownloadingReplies: 10Last Post: 1st Jan 2011, 07:46 -
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43
