Hi al,
I have Premiere Pro with the Main Concept MPEG2 plug-in, and Canopus Procoder.
I have a PAL M2V stream that I want to add my "logo" at the bottom right corner and convert to NTSC using Canopus Procoder directly from PP's timeline - it integrates to Premiere Pro smoothly, I wish Vegas could do it.....
While it is clear for me that I have to choose "NTSC DVD" preset on Canopus Procoder, I'm unsure on how should I set the project settings on PP......
As my original video is PAL, I choosed "Main Concept PAL DVD Standard" preset at Premiere Pro, and then on the encoding step I chose "NTSC DVD" on mastering quality at Procoder;
Anyway, I'm not satisfied with the results, I have already gotten much better results on this conversion loading directly the PAL M2V stream on Procoder, but now as I want to add my logo, I need the PP step;
i'm afraid I haven't chosen properly the settings in PP, hence the not so good quality as I have gotten before.
May I adjust PP settings for NTSC, even if the stream is PAL ?
I'm confused,
Thanks,
Zetti
Results 1 to 1 of 1
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Edit a HD project in Adobe Premiere pro 2?
By rajaa in forum EditingReplies: 12Last Post: 21st Apr 2009, 23:16 -
HV20 1080 24P project in Premiere Pro CS3
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 7th Feb 2009, 17:23 -
Editing in Premiere Pro 1.5 (project preset: widescreen or custom?)
By vid83 in forum EditingReplies: 0Last Post: 27th Dec 2008, 23:53 -
Small Quicktime Clips in a Premiere Pro Project
By foochuck in forum Newbie / General discussionsReplies: 0Last Post: 25th Jul 2007, 22:27
