Ok...this might sound odd but it's really somthing Im not sure. When I burn my iso, is there any differences when I select the .mds? I notice every iso I make there is a .mds go with it. Usually I select the iso file only and it burns fine, but not sure what the .mds is and if it will work the same way. Thanks!
.mds files contain metadata for your iso image. Basically, they contain added information about how to burn your disk. Generally you don't actually need the information in the .mds file unless you are burning on dual layer media or from split images (one image split into chunks to get around Fat filesize limitations) but if you've got both the iso/img and the .mds, just load the .mds. It can't hurt.
By all means use the .mds. I just got the latest DVDDecrypter and copied a DVDR using ISO>READ / ISO>WRITE. When I selected the ISO to burn, Decrypter admonished me for choosing the wrong file. It said it would choose the correct one for me, but I was not to do it again!
:P :P
Pull! Bang! Darn! -
Really? I haven't upgraded yet. I guess he's trying to get people in the habit of using the .mds now that double layer recordables are slowly starting to be used.
.mds (image file) to .mkv conversion - how ?
By shuq in forum Video ConversionReplies: 1Last Post: 29th Jul 2010, 08:30 -
Why Does ImgBurn Only Sometimes Build an MDS File with ISO File?
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 13th Aug 2009, 23:36 -
Need help converting an .MDS file into a .VOB file can anyone help??
By casper1910 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2009, 04:08 -
Help me! I can't play file *.mds file after i 'mount image' using daemon
By i_nui in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 13:04 -
Creating mds file
By StoryDonut in forum Newbie / General discussionsReplies: 2Last Post: 9th May 2007, 08:12
