Encore rejects my attempts to add an image to the background library with "unsupported file format". My file looks just like the included choices and afaik has the same properties. Anyone know what I'm missing?
That's because it only accepts Photoshop File Format .PSD
All graphics have to be .PSD I think.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Thanks, but I meet that requirement. Also, my image, like the included ones, is 720x480, and I even adopted their naming convention, i.e. NTSC...BG. Any other suggestions?
If that's true that's lame. Are you sure that's not just for custom menus with objects. I would be very suprised if a tool of that caliper disn't import just about any image format for a simple background.Originally Posted by jtoolman2000
jtoolman2000,
Are you using photoshop to create the image? -
Yeah, image is created with Photoshop.
And yeah, Encore may have wonderful attributes, but don't get your expectations up too high for "optional" features like a mature UI and support for different file formats. It's very much Version One (it says 1.5, but I guess the .5 was very ad hoc fixes) from a shop that obviously had a budget and a schedule and a whip for those who dared say "but chief, we need..." Even a triviality like the expected "open previous project" function is limited to picking from the standard Windows recently-used-files list at the bottom of the Files dropdown. Not sure why they weren't in a position to reuse the code that does that with a little more class in Premiere. Corporations hoot about code reuse, and then set up development teams that seem more like clean room operations. -
Ok I just created a blank menu ( BLACK ) I imported a JPG as an asset and just dragged it into the black menu and the image replaced the black BG in the menu. I think it has to be a PSD only if you want to import it directly as a menu. So yes, you can drop an image ( works with Jpgs so far ) over an existing menu and replace it.
I make menus in photoshop. Anything you want to be a button has to have the layer named with a (+) after its name on the layers pallet. That will apparently tell Encore to treat it as a button. Of course you can always convert anything to a button in Encore by selecting it, right clicking and choosing convert to button and visaversa, you can convert a button object to a normal graphic with the same right click command.No DVD can withstand the power of DVDShrink along with AnyDVD!
TMPGenc Authoring Works 4: Import custom Buttons
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 31st Aug 2016, 22:14 -
Encore CS4 screws up chapter selection on custom menu (video demo inside)
By aple in forum Authoring (DVD)Replies: 1Last Post: 31st Jul 2011, 10:53 -
Video buttons and background music with Adobe Encore 2
By Doomed Space Marine in forum Authoring (DVD)Replies: 7Last Post: 7th May 2011, 01:10 -
how do you add image as background for video?
By madaks in forum Video ConversionReplies: 1Last Post: 21st Apr 2011, 00:48 -
Tmpgenc DVD Author 3 Custom Background Quality?
By haym in forum Authoring (DVD)Replies: 1Last Post: 29th Jul 2008, 19:49
