  1. I was just wondering exactly what equipment I would need to view freeview on a laptop. I was looking around at some USB receivers, can anybody recommend one?
  2. This won't be much help to you, but just bear in mind that you have to have a really good aerial to get freeview reception in most of the UK. (If I understand correctly this will no longer be the case when analogue broadcasts are switched off in a few years, and the digital broadcasts can be turned up, as they'll no longer interfere with one another).
    Also, see www.freeview.co.uk for details of coverage if you haven't already.
    When I got a PCI DVB card a few years ago with the intention of getting freeview on my PC, I was really disappointed to find that the aerial in my flat at the time wasn't really up to it, and the results were very disappointing. A little while later that PC got stolen, so it wasn't really an issue any more
    The reason I thought it might be worth pointing this out is that you say you want to get Freeview on a laptop; I don't see any reason why it shouldn't work fine at home plugged into a decent rooftop aerial etc.., but I wouldn't have thought it would be much good on the move.
    I would need a fair bit of persuasion that it was worth getting a DVB receiver for a PC/laptop now, as set-top boxes have become so cheap.
    Sorry if you already knew all that and I'm preaching to the converted.
    cheers,
    theDruid.
  3. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    With any DVB /t card, you can grabb the DVB terrestrial transmissions (using third party software at least)
    La Linea by Osvaldo Cavandoli
