Hi there,
I am having trouble with audio falling out of sync after I convert an avi file to an SVCD MPEG-2. Its happenned with the last 2 videos I have convereted but never before.
Firstly, when I open them in VirtualDub it says about re-writing the header of the audio. From reading through the forums i read that with VirtualDubMod you can say 'no' to virtualdub re-writing the header so I click no and extract the WAV as I would normally. I then use TMPGEnc to convert the avi and wav file into one SVCD MPEG-2 file. But when I watch the converted file the audio is out of sync even though I said no to re-writing the header (the original avi file is all in sync).
So then I used tmpgenc to try and correct the audio sync using http://www.gromkov.com/faq/faq2004-0064.html but it turns out the audio goes out of sync more as the film goes on! How can I stop it from going out of sync in the first place?!
Please help!
Thanks!
chromeman
I'd extract the wav with Goldwave - just load the AVI, Save WAV.
Also, make sure that:
There are no bad frames in the AVI.
You encode to the same frame rate as the source.
/Mats -
Originally Posted by chromeman
/Mats
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
So frustrated! DVD Rips -> [anything] with Quick Sync = choppy.. sometimes
By s_mack in forum Video ConversionReplies: 39Last Post: 7th Jan 2012, 20:32 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Frustrated trying to burn SVCD
By InfoSeek in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2010, 20:34 -
frustrated with VDMOD and MSU sub remover
By volam in forum SubtitleReplies: 1Last Post: 7th Feb 2008, 08:45
