In the new version (rc1) if I select AC3 audio when converting an Avi with 5.1 AC3 audio, will the 5.1 AC3 be retained or will it be re-encoded to 2.0 AC3?
I believe it will leave the audio untouched. I have never had a sample to test that however. Can you try & let me know?
Tested, and works 100%, perfect 5.1 audio. Will today try and encode SVCD resolution with 5.1 too and see if that is possible.
Excellent! SVCD resolution should be no different... Let us know.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 16:25 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
