Results 1 to 15 of 15
  1. Does anybody have this drive? Is it any good? Is bitsetting available on this drive?
  2. Great drive with bitsetting. Great selection of hacked firware available also.
  3. where do i get this hacked firmware?
  4. I've had this drive for three weeks and it is the best one I have ever had. Bittsetting, riplock and Hacked firmware galore. You won't go wrong with this drive.
  5. Got this drive for my new system.
    very nice results. excelent drive for the cash
    drink up....the world's about to end
  6. I have burned a couple of hundred Ritek G05s, Prodisc S03s, Ricoh W11, and Ritek R03s and they all are very good burns (R03s are only good). I have yet to see a coaster and I would buy another drive in a minute.
    Still a few bugs in the system...
  7. I've burned around 1000 discs and haven't had a coaster yet, Prodisc S03 discs.
  8. The NEC 3500 is the vessel with which God himself speaks.
    300+ burns and not a coaster in the lot.
    I am Jack's medulla oblongata
  9. I have this drive. I purchased it from Newegg in September.
    Question: Can I upgrade the firmware to the latest version 2.18? I have 2.16 on it now.
    I downloaded the firmware upgrade but I temporarily held off doing the upgrade because the text file that came with it said that it wouldn't work for OEM drives or external drives.
    I bought mine as a bare drive from Newegg and installed it in a Bytecc USB 2.0 enclosure. I have it plugged into the PC via USB.
    Does this mean I can't upgrade the firmware either because it's an OEM drive (not sure) or because I have it hooked to the PC via an external enclosure?
    Any help will be appreciated.
  10. What is the difference in the new firmware? I'm using the old 2.16 on an OEM drive, it works fine.
  11. I'm not sure of the difference, but I think the newest firmware may allow you to burn at higher speeds. I burned my first dvd last night and it seemed to take forever.
  12. FW always comes with notes. thee new FW, 2.18 just has more media codes in it, won't change anything else or so they said.
    https://www.videohelp.com/dvdwriters
  13. Forgive my lack of knowledge with advanced features of DVD burners, but what exactly are bittsetting and riplock?
    And why would you use hacked firmware?
  14. riplock = limits speed you can rip a disk.
    If you don't know about these things, its really not important.
