Results 1 to 9 of 9
    Twilight Zone
    I just got some Velocity DVD+R 8X from Amazon for $26.99 shipped. They are Prodisc S03 if anyone is interested.
    http://www.amazon.com/exec/obidos/tg/detail/-/B0002KQRB4/qid=1106021850/sr=8-1/ref=sr_...photo&n=507846
    Shovels Rule!
    Twilight Zone
    Forgot to add that they have some DVD-R 4X inkjet printables for the same price. Don't know what the media code is, didn't order them but thought about it. I wasn't ready to gamble that much, not knowing for sure if they were hub printable or not.
    http://www.amazon.com/exec/obidos/tg/detail/-/B0002KQRGE/qid=1106022210/sr=8-3/ref=pd_...onics&n=507846
    Shovels Rule!
  3. only_emo_kid
    Guest
    looks good to me!!
  4. I bought a 25 pack of these discs from Amazon and they were Optodisc OR8 media code, I despise Optodisc, I've had VERY bad luck with them. I've burned a couple of these and they had decent PI/PO tests and played OK, but I don't trust them one bit, not to mention they had visible flaws in the dye. It looked like smudges, for lack of a better description.
    I've heard of others getting Optodisc in the 25 packs, although I'm not sure if I've heard of anyone getting Optodisc in the 100 packs. Either way, consider yourself warned (If they are prodiscs, it is a pretty good deal though).
  5. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    i TOO GOT THE 25 PACK AND THEY WERE OPTODISC, i BOUGHT 6 PACKS OF THEM WHEN THEY SOLD FOR $4.99, SO DESPITE THEM BEING CRAPPY OPTO'S, THEY BURNT FINE AND ARE CHEAP.
  6. only_emo_kid
    Guest
    anywhere they sell for 4.99$ now?
    These are OPTODISC +R media.
    PRODISCS03 is DVD-R media, not +R. I can only hope nobody bought these thinking they were PRODISC. If so, go cancel. Considering you have to use 2-3 to get a single good burn (usually, unless you're lucky), the "deal" is more like 75 cents per disc, in the end. Not to mention wasted burn time.
  8. People have gotten MCC and Prodisc media codes as well, so it's just a matter of how lucky you're feeling I guess. I think that the 100 packs in particular used to be mostly Prodisc media, but I don't think that that can be counted on anymore.
    snoland - it sounds like the ones you've ordered recently are Prodisc - are you just assuming this, or have you received them and checked their media code?
    Twilight Zone
    oops, sorry folks. I was thinking R but I typed S. Here is the media scan from info pro.
    Media Information
    Region information N/A not a DVD-VIDEO
    Media code/Manufacturer ID PRODISC R03
    Media Product Revision Number 03h
    Free Blocks 405405696
    Free Capacity 4.38GB(4.70GB)
    Book Type DVD+R
    Media Type DVD+R
    Media Id Code Speed 8.0x 11080KBps
    Available Write Descriptor CLV 8.0x 11080KBps
    Available Write Descriptor CLV 5.9x 8112KBps
    Available Write Descriptor CLV 4.0x 5540KBps
    Available Write Descriptor CLV 2.4x 3324KBps
    Linear Density Blank Disc
    Track Density Unknown
    Number of Layers 1
    Shovels Rule!
