    Jan 2005
    boston
    When I open it with Windows Media Player, it just says 'connecting' and does nothing, so I tried it VirtualDub to check for errors, it gave me this error: "No video frames found in MPEG file."
    I then tried it with a DivX player, that also did not work, but then I tried it with Winamp, which recently started supporting video, and it worked fine, the only problem was I couldn't use the seek bar to fast forward or rewind.
    Has anyone ever experienced this?
    Any advice?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    install a mpeg2 codec ..
    easy way is to install powerdvd or windvd
    also
    use vitualdubmod instead of virtualdub to open mpeg2 files
    Jan 2005
    boston
    I already have that codec installed, and I just uninstalled/reinstalled it to make sure, and I'm still having those problems.
    anyone else?
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    can you play it in powerdvd ?
    have you tried using media player classic instead of media player ..... much better program .
    Jan 2005
    boston
    i converted it to mpeg using TMPGEnc, and it worked fine after that
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    you said it was mpeg to begin with
    Jan 2005
    boston
    you're absolutely right
