I use DVDMaestro for authoring my DVD project and it's simply the best that there is (full creative control and everything you'd wish for, except ...) Since it's an older program there is no built-in option for rendering motion menus and these need to be authored separately and imported to DVDMaestro. Any recomendation for a tool/program for creating motion menus? Ideally, it should provide for full creative freedom whithout forcing you to use presets etc. (optional presets for buttons and backgrounds are fine but they should not be mandatory) and without being overly 'user unfriendly' (I'd say my level of DVD authoring proficiency is high intermediate to advanced).
Any suggestion is appreciated. I know of DVD Menu Studio, but this appears to be for still menus only.
Thanks.
As you said motion menu's are just mpeg clips. Adobe After effects is great for creating them but its not easy to learn. Any video editing tool can be used in addition to photoshop for the buttons etc
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 16:45 -
Best tool for PAL to NTSC without jerky motion...using TMPGenc
By funkymix in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 12:59 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
GFD motion menu stuttering
By spamiaint in forum Authoring (DVD)Replies: 2Last Post: 15th May 2008, 10:58
