I'm on the final part of backing up my dvd in dvd decrypter when I get the following message:
I/O ERROR
DEVICE {0:0:0}DVDRW IDE 16XA079(E)(USB)
SCISTATUS:0X02
INTERPRETATION:CHECK CONDITION
CDB:2A 00 00 0F 45 20 00 00 20 00
INTERPRETATION WRITE (10)-SECTORS: 1000736-1000767
SENSE AREA 70 00 05 00 00 00 0A 00 00 00 00 21 02 00 00 00
INTERPRETATION: INVALID ADDRESS FOR WRITE
I'M A NOOB IN THIS HOBBY SO ANY HELP IS GREATLY APPRECIATED.
i'M RUNNING AN I/O MAGIC 16X EXTERNAL DVDRW+R-R DOUBLE LAYER BURNER. I WAS TRYING TO BACKUP A COPY OF MASTER AND COMMANDER. AGAIN THANKS FOR THE HELP.![]()
Maybe bad media or you bump the computer hard.
More info needed. -
Sounds like bad media. What media are you using? Try burning at a lower speed.
thanks for the tips guys, I retried the burn on a lower speed with a new dvd+r and it worked. Again thanks for the tips.
P.S. Sorry about the all CAPS.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 08:09 -
Samsung dvd-4155 DVD Player/recorder format problem
By jamesd1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th May 2009, 22:51 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37
