  1. devdev devdev's Avatar
    Sep 2003
    hi
    Any thoughts on best way to transfer cine film to dvd without flicker effect?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    what kind of telecine set up are you using ?
  3. devdev devdev's Avatar
    Sep 2003
    hi thanks
    8mm projector into video transfer box (turns image 90 degrees) into a digital camcorder. speed of projector set to 16.6 secs (for uk pal) to avoid flicker effect.
    The problem that remains is hotspot (centre spot burnt out when image dominated by highlights)
    hope this enough
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    always an issue with one light telecines ..
    you can try to use a 30% glass ND filter or a screen to cut down the light ... also - if you can defocus the bulb (used a lot in short throw theaters to prevent some hotspots)
  5. devdev devdev's Avatar
    Sep 2003
    great - thanks
    appreciated
    i cant seem to find a old telecine machine anywhere!!
  6. devdev devdev's Avatar
    Sep 2003
    thanks
