  1. Hi
    I've just spend the last three days editing 3 hours of DV footage in Pinnacle Studio 9. So I was finally done with everything and went to the "make movie" menu. I chose to create it as a dvd with highest quality as possible, and besides that just the ordinary settings (if you want all the settings please do tell). I came back from work and the movie was rendered and burned. But the DVD wouldn't play in my stand alone DVD player! It's a Nintaus N9901 by the way.
    I checked and it does support DVD+R (I used an Advanced AZO 8x Verbatim DVD+R disc). Then I tried to pop it into my computer, and WMP just went down trying to play it (I have a dvd codec loaded, and it usually takes everything else). WINDVD played it fine though!
    SO! Why did this happen? Can I fix it? If not can I use some other application?
    Right now I've got two .m2v files and a .wav file with the soundtrack.
    Hope you can help!
    Thank You!
  2. When you say "right now I've got....." where do you have these files?
    I use Pinnacle for editing and sometimes encoding ("rendering" in Pinnacle lingo) but usually use anothe Authoring (TDA) and Burning program (Nero).
    I have successfully done the whole thing from Pinnacle, but only small projects.
  3. I have them in a folder... I've tried to play them in windvd, and they work fine. So you suggest TDA for authoring?
  4. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    Ah it's nice to see Pinnacle still hasn't made improvements
    I have Studio 8 and have never gotten it to make a DVD.
    I also use Pinnacle for Capture and edit, I always output to DV-AVI, then use TMPGenc Plus 2.5 to encode to MPEG-2 and TDA to author.
  5. hmm maybe I should consider that... But TDA? What is that? Cannot find it in the toollist.. I figure it's there... but dunno what TDA is short for
  6. TMPGenc DVD Author (or something like that). Look in the DVD Authoring tools section. Many here use it so there are tons of posts about it.
    That's the same method I normally use when using Pinnacle to edit. Either TMPGenc or Procoder for encoding and TDA for authot, Nero to burn.
