  1. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    I have a leadtek ti4600 video card my vivo edition and used it to record a tv show and after it recorded, I played it back and the audio was out of sync by almost 2 sec. Is there a fix to this. No matter what player I used I had the same problem.
    Thanx All.
  2. Member mastersmurfie's Avatar
    May 2003
    almost certainly has to be some "fix" in the sticky at the top of the Capture forum...
    could be any number of things...
    just a thought
    mastersmurfie
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    What capture program did you use and what codec for video and audio etc.
    If it works with your hardware (not familiar with your capture card) try VirtualVCR and use the resampling audio method of A/V sync. Look in the included HELP function and it tells you more or less how to set it up.
    VirtualVCR is freeware so worth trying it out.
    - John "FulciLives" Coleman
