I have been trying to edit a MPG I captured with my Terapin. I use VCDGear to convert the .DAT file, and then I try to edit the MPG. The unedited MPG plays just fine, but when I try to cut it with TMPGEnc, I am able to select my cuts, but when I do the 'RUN' the final file never gets generated beyond the same point in the original mpg ever. I can't see anything wrong.
If I can scan the file and find a corrupt bit, and fix it, that's what I'd like. But I'm not sure what tool to use.
I'd appreciate any advice, or assistance.
Lyman
what i do is take the .dat file by clicking browse (all files) and you have the dat file for audio and video..
specify the output file, (mpg) and start......
converts the dat to mpg
then you can cut and edit your mpeg
have you tried capturing black and white tv programs from vhs???
i am having a bad time with that (extremely poor quality)
TMPGENC 4.0 Xpress Weird Problem! (Shows Green Bar On Left Side Of Video)
By hypnoticpimp in forum Video ConversionReplies: 16Last Post: 11th Jan 2010, 07:36 -
By hypnoticpimp in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2009, 02:17 -
By hypnoticpimp in forum Authoring (DVD)Replies: 1Last Post: 14th Apr 2009, 09:05 -
TMPGEnc DVD Author 1.5 Problem... Only with these files... Weird, Help!
By acid_burn in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2008, 12:50 -
xvid files act weird in TMPGENC
By briansmccabe in forum Video ConversionReplies: 4Last Post: 11th May 2007, 22:53
