My HDTV is a 16:9 aspect ratio set. I capture in AVI using Virtual Dub, and convert using TMPGEnc. Can anyone tell me the best settings in each of these two softwares for capturing the original video (say, something coming through my DishNetwork receiver) and converting it in TMPGEnc so it looks the best when played on my 16:9 ratio TV?
Hello,
Just make sure the "source display" is set to "16:9 display" and also use "keep original aspect ratio". Use those two settings and the video SHOULD look just like the original in terms of proportions....
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Aspect Ratio setting in VirtualDub Capture mode
By alesco in forum Capturing and VCRReplies: 34Last Post: 6th Feb 2012, 10:23 -
need to correct Aspect Ratio by padding/adding black bars - author AVCHD
By texas1 in forum Authoring (Blu-ray)Replies: 3Last Post: 24th Nov 2011, 12:44 -
AVStoDVD: How do I make default settings for all files to aspect ratio 4:3?
By Heyjoojoo in forum Authoring (DVD)Replies: 8Last Post: 30th Aug 2010, 23:49 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 04:57 -
dv/ulead capture, aspect ratio problem
By Statick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th Jan 2008, 16:46
